Discussion topic: Sky multi room box not working
Message posted on 16 Oct 2024 12:27 PM
One sky box will not turn on, and master Box does fails to communicate with other boxes if TV is pushed back into the enclosure and additionally sky broadband extender does not work and broadband keeps dropping off
Message posted on 16 Oct 2024 04:05 PM
Re: Sky multi room box not working
Hi @jk69
- Who is your Broadband supplier?
- Assume you have a Sky Q WiFi booster. Where is it located (in relation to other Q boxes) and to what is it connected?.
Regarding the box that will not turn on,
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Message posted on 16 Oct 2024 04:07 PM
Sound like a job for a Sky Engineer to visit with all those issues
SkyQ [H/W: 32B106] + 3 mini
Samsung 55" Neo QLED UHD TV
Swish Fibre 150 Symetrical
Linksys MX5400 Mesh network
