Discussion topic: I have Sky Q with multi room and today am unable to access any channels on my second box.
This message was authored by: Mike248
On my second box all the normal channels are appearing on the TV guide screen, but when I try to select one I get a message saying "Please check your subscription entitles you to view this channel on this box".
I have had multiroom for a long time and have never had this issue before.
Re: I have Sky Q with multi room and today am unable to access any channels on my second box.
Hi @Mike248
Reboot the mini as above.
Avatar for Mike248
Hi old fella. I've tried all that, but no joy.
I've got an internet connection to my second box and all the channels are available on the Menu, but when I try to select one it keeps coming up wiith the same message about checking my subscription.
"Please check your subscription entitles you to view the channel on this box "
It's as if Sky has removed my multiroom subscription without notice, but I'm still paying for it.
many other thoughts?
