3
This discussion topic has been answered Discussion topic: Sky minibox
This message was authored by: Dave445
Sky minibox
Sky Q won't connect to mini box
Message says I need authorisation to use minbox
Re: Sky minibox
Hi @Dave445
Assume you have the monthly Sky Q Multiscreen subscription?
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Re: Sky minibox
@Dave445  I'm not sure why you posted this on the Sky Go board as that is an app, your post has been moved to the correct board for Sky Q
Re: Sky minibox
Hi @Dave445
Avatar for Dave445
Re: Sky minibox
Many thanks
back to full function
