Discussion topic: No ip adress found
This message was authored by: Sue284
No ip adress found
Just had full fibre connected today, since then we've not been able to get our sky q box or mini boxes to connect. We have followed all the usual steps but still recieving errr code No ip address found. What does this mean and how can I fix it?
Re: No ip adress found
Hi @Sue284
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new white Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Also with the Sky Max router you need to connect mins to the main Q box using WPS
Avatar for Sue284
Level 0 icon
Thankyou. I will give it a try
