Discussion topic: Sky mini
This message was authored by: ledzepp1v
Sky mini
Sky mini stuck on orange light
Re: Sky mini
Hi @ledzepp1v
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
