Discussion topic: Sky mini stop working
Message posted on 15 May 2025 01:54 PM
1 of my mini boxes has stopped working, do I just order another 1, or done sky replace it
Message posted on 15 May 2025 01:58 PM
Re: Sky mini stop working
Mini boxes are loaned to you and must be returned to Sky at the end of a subscription or if faulty.
Whats the issue you're having?
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Message posted on 15 May 2025 02:02 PM
it's not starting up after u turn it on. it's getting to the blue screen when it says, "to hit home button when screen goes blank" then thats it. not comin on again after that
Message posted on 15 May 2025 02:07 PM
Have you tried rebooting your broadband first, then a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 15 May 2025 02:10 PM
we have 3 mini and the other 2 is working no problem, just this 1. we have turned the mian box off and then reset the mini which isn't working. and still no hope after the blue screen. many thanks tho. next step is to phone sky to get it lifted.
