Discussion topic: Sky mini boxes
Message posted on 30 Sep 2024 07:10 AM
Sky mini boxes
I have just moved home and the engineer came to install our sky. Unfortunately our mini boxes were still packed at the time so he couldn't set them up. We now have them out, gone through the set up process and none of them will connect. Tried all the trouble shooting and still nothing. Any ideas?
Message posted on 30 Sep 2024 09:30 AM
Re: Sky mini boxes
Hi @Emma1602
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Failing all of the above you may need a Sky Q WiFi Booster to position midway between your main Q box and the minis and you will need to contact Sky directly.
