Discussion topic: Sky mini boxes keep disconnecting
This message was authored by: Mj16
Sky mini boxes keep disconnecting From main box
Re: Sky mini boxes keep disconnecting
Hi @Mj16
Try completly reconnecting.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
