Discussion topic: Can’t connect tv to the sky router
This message was authored by: Sarahomara
I can't connect the tv to the broadband
Avatar for Sarahomara
Level 0 icon
Re: Can’t connect tv to the sky router
Can you help me pls
Hi @Sarahomara
