Discussion topic: Sky mini box
Message posted on 17 Mar 2025 09:23 AM
Sky mini box
After changing password on BB hub, I cannot get the minibox to work!
Main Q box and connnects are OK.
Help!
Message posted on 17 Mar 2025 09:34 AM
Re: Sky mini box
Help!
Hi @fulwellg
Reboot the mini as above.
