Discussion topic: Sky mini box
Message posted on 04 Mar 2025 07:58 PM
Sky mini box
Message posted on 04 Mar 2025 08:40 PM
Re: Sky mini box
@Matty41 wrote:
I have multi room, been having issues with broadband, finally got that all fixed, got new router extra, but the sky mini box upstairs is saying no programes on any of the channels and coming up saying check your subscription, but it definetly part of my subscription and been paid for. Getting all apps and it showing TV guide, just won't let us watch normal tele or recordings, main sky q box downstairs working fine. Just before ring them anyone any ideas please
Hi @Matty41
Try a Reset Settings in the main Q box hidden menu.
Once the main Q box is completely back up and running reboot the
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your mini remote or if this is not working press the standby button on the front of the mini box (Amber led)
Message posted on 04 Mar 2025 08:49 PM
Re: Sky mini box
Thank you will try that I'm morning
