Discussion topic: Sky mini box
This message was authored by: Bec2923
Sky mini box
My sky mini box upstairs seems to go all fuzzy on recordings but the one down stairs doesn't
Re: Sky mini box
@Bec2923
Any error message displayed? Have you tried a reboot?
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if necessary-
~ press the 🏠 button
