Discussion topic: Sky mini box
This message was authored by: Lucyj78
Sky mini box
My sky subscription is saying we don't have sky q mini and we do none of my boxes are working
Re: Sky mini box
Di you get any Messages on your Main Q box @Lucyj78
If so what??
Avatar for Lucyj78
Level 0 icon
Re: Sky mini box
Yes it says this
You don't have the required subscription to use a sky q mini box.
but we do and I've rand and checked and they said we do and said they don't know what's wrong
Re: Sky mini box
Hi @Lucyj78   Did they advise a power reboot of everything including your broadband router to refresh its DNS. The viewing card inserted correctly.
Avatar for Lucyj78
Level 0 icon
Re: Sky mini box
They offered another number that was it and that got me into this forum. It's in my subscription it was working and now it's now it's so frustrating
Avatar for Lucyj78
Level 0 icon
Re: Sky mini box
Also my sky mini box says it's connected to the sky box well one of them does the other doesn't
Re: Sky mini box
@Lucyj78 wrote:
Yes it says this
Hi @Lucyj78
You said in your post that none of the boxes are working..
Does the above post mean that the main Q box is working.
If it is see if a Reset Settings in the main Q box hidden menu helps.
