Discussion topic: Sky mini box
Message posted on 06 Nov 2023 07:52 PM
Sky mini box
We got a new router and since then our sky q mini box is not working. We can't even get the controller to work with the box. We've tried pulling out leads and resetting etc. Thanks
Message posted on 06 Nov 2023 07:56 PM
Re: Sky mini box
Hi @Gaz8
Reboot the mini as above.
If you had to press the standby button on the front of the mini to turn it on Try completly resetting your Bluetooth remote.
Message posted on 06 Nov 2023 08:20 PM
Re: Sky mini box
Amazing. Thank you. Thats us connected. Thanks
Message posted on 23 Mar 2024 04:00 PM
Re: Sky mini box.
The mini box in my cabin will not connect to broadband or my controller.
I do not have a new router and not sure why this has happened. I have reset everything and tried to connect by pressing wireless buttons on other boxes.
