Discussion topic: Sky mini box
Message posted on 06 Mar 2023 08:47 AM
Sky mini box
My sky mini box isn't working it's been playing up for a while and now for the last couple of days it just says it's not connected.
I have tried reconnecting it over and over again but still not working
Message posted on 06 Mar 2023 08:49 AM
Re: Sky mini box
@Chel+Doll Have you tried rebooting your main Q box ie
Then doing the same with your mini box
Message posted on 06 Mar 2023 09:35 AM
Re: Sky mini box
Hi @Chel+Doll
If a reboot doesn't solve your issue try a Network Reset on the mini.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 06 Mar 2023 10:42 AM
Re: Sky mini box
Hi Chel+Doll
I have escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the blue bubble to start the conversation.
Here's more information on how Community Messaging works - https://community.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Tom
Message posted on 08 Mar 2023 10:43 AM
Re: Sky mini box
Hi Chel+Doll
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
