Discussion topic: Sky mini box problem
Message posted on 19 Jul 2024 11:23 AM
For some reason our sky q box now turns off when we turn the tv off which means we cannot use our mini sky box upstairs.
We have gone on to settings/preferences but there is nowhere on there that would sort out the problem. Any suggestions please? TIA
Message posted on 19 Jul 2024 11:42 AM
Re: Sky mini box problem
The latest software introduced the change where the Q box will turn off when you turn the TV off.
However this should only put the Q box into Standby with the Amber led.
All other mini boxes should function with main Q box in Standby.
Message posted on 19 Jul 2024 11:45 AM
As soon as the main box goes off so does the mini box!
Message posted on 19 Jul 2024 11:54 AM
Try resetting the mini box connection.
Reboot the mini as above.
Message posted on 19 Jul 2024 12:42 PM
We've done this three or four times to no avail but thank you for taking the time to reply. I shall give sky a call to see what they can come up with.
