This discussion topic has been answered Discussion topic: Sky mini box problem
Message posted on 09 Mar 2023 09:53 PM
Message posted on 09 Mar 2023 10:00 PM
@TERRY611 wrote:
Hi, my sky mini box is not working properly. When going to sky home screen it comes on clearly but then the screen fades and it seemed to be a dark shadow over the screen. The home screen can still be seen but not at all clearly. Hope someone can help with this. Thankyoi
Hi @TERRY611
Try rebooting the mini.
To reboot press Standby on your mini remote (if the box responds to the remote), and then switch off and unplug at the mains.
Wait at least 30 secs and then Plug back in and switch your mini box back on at the mains.
Wait for the on screen instructions to disappear and the front led to turn Amber. Then wait for 30 secs before you press Home on your remote or if this is not working press the standby button on the front of the mini (Amber led)
Hi @TERRY611
Message posted on 10 Mar 2023 01:16 PM
Re: Sky mini box problem
- Hi, many thanks for your help. The problem did resolve It's self later on but will certainly try the things you suggested it it recurs.
Message posted on 09 Oct 2023 10:33 PM
Dear sir I still got same problem with my mini box stops again
Message posted on 09 Oct 2023 10:42 PM
Have got more problems with it the the not green light not coming on I need more help please I am learning difficult
Message posted on 09 Oct 2023 10:52 PM
@Sharon041 wrote:Dear sir I still got same problem with my mini box stops again
Hi
do you mean the exact same symptoms as the person who started this thread?
