Discussion topic: Sky mini box not working
This message was authored by: Phil2401
We take the sky mini box down to our garden room where we have a WiFi extender and it seems to reject the WiFi
ie we set it up it switches on works for a couple of seconds and switches off
so need to get it working
Re: Sky mini box not working
I'm assuming you have Sky Q not Sky+ and will move your post accordingly.
Hi @Phil2401
It needs to a Sky Q WiFi extender to connect Q boxes.
Beat option is an external grade Ethernet cable.  Connected to your Main Q box or your Router if on Sky Broadband.
If you have the Sky Max router or 3rd Party Broadband then you need to connect the Ethernet to your main Q box.
If all Q boxes are on Ethernet you can connect them all to your router regardless of broadband supplier.
