Discussion topic: Sky mini box multi not working
Message posted on 09 Sep 2025 04:54 PM
Tryed rebooting again nd again not working
Message posted on 09 Sep 2025 05:40 PM
Re: Sky mini box multi not working
Not a lot to go on there but if rebooting try the main box first, so
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
