Discussion topic: Sky mini box limit reached
Message posted on 17 Nov 2024 02:40 PM
Why can't I use two Sky mini boxes at the same time. It says limit reaches and second box fails to work.
Message posted on 17 Nov 2024 02:45 PM
Re: Sky mini box limit reached
You may have an older main box that only supports 1 mini.
Check the hardware version here: https://www.sky.com/help/articles/sky-software-updates
Message posted on 17 Nov 2024 02:53 PM
@TrevD
As indicated by @PandJ2020 the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
