Discussion topic: Sky mini box keeps losing connection
Message posted on 31 Mar 2024 06:09 PM
Sky mini box keeps losing connection every 5-10 mins
Message posted on 31 Mar 2024 06:16 PM
Re: Sky mini box keeps losing connection
Hi @Beckyb1991
Try completely resetting the mini.
First reboot the main Q box and then when this is completely back up and running reboot the mini.
Reboot the mini as above.
