This discussion topic has been answered Discussion topic: Sky mini box keeps disconnecting from Sky Q box
Message posted on 30 Nov 2025 06:48 PM
My Sky mini box won't connect to Sky Q box
Message posted on 30 Nov 2025 07:31 PM
@MickeyP1 wrote:
Thanks for the info.
I have tried this and it did work for a time, then dropped out again?
I've recently changed my Broadband supplier so have a new router and it seems to have happened since this.
Network connection is good on both mini boxes and Q box.
Don't forget @MickeyP1
If on 3rd party broadband (or Sky Max router), minis if on WiFi can only connect to the main Q box or a nearer connected mini.
Message posted on 30 Nov 2025 07:04 PM
Re: Sky mini box keeps disconnecting from Sky Q box
Hi @MickeyP1
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Message posted on 30 Nov 2025 07:09 PM
