Discussion topic: Bad weather
This message was authored by: Daveyh
Message posted on 30 Nov 2025 08:02 PM
Bad weather
This is ridiculous every time there is bad weather rain or wind there is no signal on any channel come now sky sort this out it's bad enough the month bill is highland can't even talked to you on and free phone number to phone to complain to talked to a English person and not foreigner who can understand stand English no wonder english people get **bleep** off with them. sort it out sky
Find out more
Message posted on 30 Nov 2025 08:07 PM
Re: Bad weather
Possibly rain is getting in the wiring. If you are seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It may then give you the opportunity to arrange an engineer. If it doesn’t you’ll need to contact Sky to book an engineer appointment.
It’s worth mentioning that:
🔹 a misalignment is not necessarily something that will be visible to the naked eye and could only affect one or two channels (amongst the first to be affected may be TNT or GB News),
🔹 wind and rain can affect the satellite signal and following adverse weather wait times for an engineer will probably be significantly longer.
🔹a Sky Q box requires a periodic 'Keep alive' signal that is delivered via the satellite so if that isn’t received the box will close down until the satellite signal is restored.
Calls go though to the next available agent wherever they are based.
We are customers here on a customer ➡️ customer discussion forum where we try to help other Sky customers. I’m afraid you aren’t communicating with Sky by posting on here.
