Discussion topic: Sky mini box isn’t working
Message posted on 28 Aug 2024 07:42 PM
The box isn't connecting to the network
Message posted on 28 Aug 2024 07:47 PM
Re: Sky mini box isn’t working
Hi @tupps
Reboot the mini as above.
