Discussion topic: Sky sports showing message ‘No viewing card’
This message was authored by Kevin55a This message was authored by: Kevin55a
I cannot get Sky Sports channels and a message saying 'No viewing card' is displayed. Never seen this before, any suggestions please?
Re: Sky sports showing message ‘No viewing card’
Hi @Kevin55a .
First try rebooting your Q box?
Failing this
First check that your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.   Push it fully in and it then pop out slightly so you can grip it.
Remove the card and give the chip a gentle wipe with a damp lint free cloth or E- cloth.
Make sure it is completely dry and reinsert it.
chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
