Discussion topic: Sky mini box internet connection problem.
Message posted on 03 Mar 2024 02:53 PM
My mini box has lost its internet connection despite its ethernet connection to the main box. The menu is showing as connected but the mini box isn't receiving a signal. When I try to connect it vai the cable, I get a message which reads 'NO IP ADRESS'. Any ideas?
Message posted on 03 Mar 2024 07:41 PM
Re: Sky mini box internet connection problem.
@ejselio try rebooting your router then when thats up and running reboot your main box then finally reboot your mini box by reboot I mean turning the power off at the wall for 30 seconds then turning it back on again
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
