Discussion topic: Sky mini box error MR102
Message posted on 11 Aug 2026 10:05 PM
Mini box will not connect, I have restarted several times with same problem
Message posted on 11 Aug 2026 10:29 PM
Re: Sky mini box error MR102
Hi @GrahamO65
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
