Discussion topic: Sky min box won’t work
This message was authored by: DanielH
The box will turn on if button on the sky q box is pressed but it no longer responds to the remote control so can't change channel or use any menu. Batteries in remote have been replaced and remote will turn on the TV so believing it to be an issue with the box as opposed to the remote.
Re: Sky min box won’t work
@DanielH Have you tried rebooting  Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
This message was authored by: emmy7luca
Sky w mini box keeps glitching
This message was authored by: Philip25
Re: Sky min box will not connect
Mini box won't connect.
it has been re booted via main Sky Q.
re starts but then fails again.
