Discussion topic: Sky max
This message was authored by: kwilson
Sky max
I have sky Q. Tv keeps saying I need to upgrade subscription to watch sky max.
Re: Sky max
Are you trying to watch HD channel without HD sub?
Avatar for kwilson
Re: Sky max
I am unsure..I have a sky Q basic package. To my understanding I should still be able to get access to sky max?
Re: Sky max
Yes, but probably only SD.  Try channel 813.
Re: Sky max
hi @kwilson
Try changing your download preference to SD
Main Menu -> Settings -> Setup -> Preferences
Avatar for kwilson
Re: Sky max
Yes I have tried HD and SD, doesn't work on either 😞
Avatar for kwilson
Re: Sky max
Ok I don't have access
Re: Sky max
Hi @kwilson
Everybody should have Sky Max. There may be a problem with your viewing card. I'm afraid a call to Sky is required. Sorry I forgot to note, you have tried a power reboot of your Sky Q Main box?
Edit: Sorry I see you have Sky Basic, so free to air channels only. Sky Max requires a Signature subscription.
Re: Sky max
@kwilson if you mean you have Sky Essentials then you will only have access to the free to view channels
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for kwilson
Re: Sky max
Alright then. Does being a silver VIP member change anything?
Re: Sky max
Nope: Max is a subscription channel, not Free To Air.
VIP status has never negated the need to subscribe.
