Discussion topic: Sky main box issues
This message was authored by: Andy4170
Sky main box issues
So the box keeps freezing and we get a very blurred screen as if the tv had blown.so we bought a new tv and we are still getting the blurred screen and programs freezing or jumping.
Re: Sky main box issues
Hi @Andy4170
This message was authored by: Aprilj38
I need to arrange someone to come out
I need an engineer to come out and move my sky dish p
@Aprilj38 Afraid you are not contacting Sky's customer services on here, this is a customer to customer forum where customers help each other.
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
