2
This discussion topic has been answered Discussion topic: Sky in another room
This message was authored by: Adriancle
Sky in another room
I've got sky downstairs, would be interested in another box in bedroom
This message was authored by: Laing1 Answer
Re: Sky in another room
@Adriancle if you do not have any other mini boxes then you need to take the multiscreen subscription out at current list price of £15 and you need to order a mini box you might get the first free or you might have to pay and admin charge of £50 all mini boxes are loaned to you in the same way that main boxes are
You can have a maximum of 4 mini boxes loaned to you by Sky.
All 2TB boxes and the UHD/HDR 1TB permit watching on two mini boxes and the main box at 1 time. You may also be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
The older 1TB non UHD box only allows you to watch on 1 mini box as well as the main box .
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Adriancle
Thank you so much👍
