Discussion topic: Sky hd channel moved
This message was authored by: Daniel27
Hi can anyone help, all my hd channels have changed from the normal numbers to channels in the 800's but only come up on the hd section on the tv guide. They usually  are the standard 101, 102 ,103 channels?
Re: Sky hd channel moved
Hi @Daniel27
Assume you are looking in your Q box and not the Sky Go App?
Try rebooting your Q box.
This message was authored by: Invisiblename
Often find that if you turn the power to your Sky Q off & on, the planner will reset itself
I am just another Sky customer!
