This discussion topic has been answered Discussion topic: Sky go remote sky q
Message posted on 03 Aug 2023 09:52 AM
Good morning all
I've recently downloaded the remote control on the sky go app
Can anyone advise can you turn the volume up using this remote as I can't see how to ?
thanks in advance
Message posted on 03 Aug 2023 09:59 AM
You can't control the volume using the Sky app as the real Sky remote uses IR to change the volume and turn the TV on/off.
If your TV has an app, you could use that instead.
Pete.
Pete.
Message posted on 03 Aug 2023 10:01 AM
							Re: Sky go remote sky q
Thank you Pete
