1
This discussion topic has been answered Discussion topic: Sky dish
This message was authored by: stew7
Sky dish
How do I get in touch to relocate my sky dish
Re: Sky dish
@stew7
Sky charge about £65 for this if you have Sky Q.
These are the current methods for contacting Sky, and depending on the issue some will be more appropriate than others …
🟢 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟢online help via this link
https://www.sky.com/help
🟢Sky Assistant 💬 should also be available via
🟢Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟡Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed at a weekend.
Re: Sky dish
@stew7
