This discussion topic has been answered Discussion topic: Sky dish
Message posted on 30 Dec 2025 10:42 AM
Need to have our sky dish moved due to building work
Message posted on 30 Dec 2025 10:44 AM
You'll need to contact Sky to arrange. They charge in the region of £65 and another £65 afterwards if it needs returning to it's original spot. Perhaps get a quote from a local satellite company which may be quicker.
Message posted on 30 Dec 2025 10:49 AM
Re: Sky dish
Thanks for that - do you know which is best number to phone them on, so that I have the option
Message posted on 30 Dec 2025 10:51 AM
Re: Sky dish
@JadiniBeach
These are the current methods for contacting Sky, and some will be more appropriate than others …
🟧 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you have Sky Broadband. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟧online help via this link
https://www.sky.com/help
🟧Sky Assistant 💬 should also be available via
🟧Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
🟩Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Message posted on 30 Dec 2025 10:54 AM
Re: Sky dish
Thank you
Message posted on 30 Dec 2025 11:03 AM
Re: Sky dish
hi @JadiniBeach
Note it may be quicker (& possibly cheaper, although I don't know) to use a local Satellite installer
Message posted on 16 Feb 2026 06:17 PM
Re: Sky dish
I need a sky dish fitted
Message posted on 16 Feb 2026 06:23 PM
Re: Sky dish
If you've contacted Sky to join Sky Q, a dish will be fitted if there isn't one already.
