Discussion topic: Sky dish removal.
Message posted on 17 Jun 2024 06:09 AM
Sky dish removal.
I'm cancelling Sky Q and going streaming. Would having a dish removed from the side of the house leave nasty holes? Is it safer just to leave it? Also what about internal aerial cable, can I just cut it back to the entry point?
Thanks.
Message posted on 17 Jun 2024 07:15 AM
Re: Sky dish removal.
Thanks.
Hi @Mitch16 As the SKY dish and cabling are your property you can remove them from your premises, if you wish to leave the dish in place there shouldn't be a problem, there would be small holes in the wall if removed, you could always pay a local engineer to remove everything and make good any holes etc.
