Discussion topic: Sky dish needs to be moved
This message was authored by: Kelly1978
Had sky q put in today I wasn't at home had my brother let them in as I was at work. I've come home and the sky dish is too low its all I can see when I look out of my window. How can I get this moved
Re: Sky dish needs to be moved
@Kelly1978
Sky should have consulted with your brother (if he was the responsible adult at the address), however it may have been the only suitable place within the guidelines the engineer works to regarding positioning and height.
hi @Kelly1978
I have escalated your post to a team that assist customers posting here - hopefully they will get in touch with you
Hopefully they can advise what options are open to you.
Please see this link re the escalation and what you might see:
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
If you are using Safari I believe you must make sure that 'Hide IP adress' is not checked in settings to be able to see it - if you have difficulty finding that setting then may be try accessing here with another browser
P.S. I am guessing it may help if you can take some pictures ready to send them when they make contact
Avatar for Kelly1978
Thank you 😊
Hehe engineer didn't ask him. And it's so much lower than any others on the street.
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to Kelly1978.
