Discussion topic: Sky controls not working
This message was authored by: Paul1408
 Changed batteries and switched power off and back on but no joy
Re: Sky controls not working
Try repairing your remote as described on step 3 of this Sky Q help article;
https://www.sky.com/help/articles/fix-remote
Hi @Paul1408
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on then try completly resetting your Bluetooth remote with the Q box on.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
