Discussion topic: Sky cinema
This message was authored by: Nickherbert23
Sky cinema
Hi we signed up for sky cinema this morning waited all day still hasn't come on its saying to upgrade
Re: Sky cinema
hi @Nickherbert23
Check in your My Sky at the bottom of the Home menu.
See if it is shown yet in your package.  It may take a while to be added to your Account
Re: Sky cinema
@Nickherbert23 It can take upto 24 hours but normally less. Have you tried rebooting your main Q box ie
if that doesn't work
You could try refreshing your viewing card by pressing home > settings > system info > viewing card number > setup > viewing card setup press select to trigger a callback don't worry nothing to do with your phone its only Sky's terminology this will be done over the internet
or you may have to call Sky  if none of the above work
You can contact Sky by phone by dialling 150 if Sky is your phone provider or by following the link below
https://www.sky.com/help/home
scroll down to need more help click on this and you will find a phone number. If you are in ROI please change the flag at the bottom right to the ROI flag
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
