Discussion topic: Recent upgrade to sky sports and removal of hd now having problems with screen flickering
Message posted on 15 Jun 2024 03:46 PM
Screen flickering at start up after changes to sky package
Message posted on 15 Jun 2024 03:55 PM
Re: Recent upgrade to sky sports and removal of hd now having problems with screen flickering
Hi @andy+peace
Certainly not likely to be anything caused by a package downgrade .
Message posted on 15 Jun 2024 07:04 PM
Still flickering when I change channel then stops .worse on start up !
Message posted on 15 Jun 2024 07:15 PM
Hi @andy+peace
I suppose you are now watching SD content.
Perhaps I should have considered this in my earlier post.
This is vastly inferior to HD content.
If you have Sky Cinema (which is in HD as Standard) then check one of these HD channels to see if is any better.
Message posted on 15 Jun 2024 07:20 PM
Have sports in hd. flickering happens when changing sports channels .never happened before this upgrade last week
Message posted on 15 Jun 2024 08:07 PM
Yes OK @andy+peace
Misread your first post as I thought it meant you had removed Sky Sports and the Q HD pack.
The only other thing I can suggest is to try another HDMI to eliminate this as an issue.
Failing this it's possibly best to get an Engineer from Sky to check.
Message posted on 15 Jun 2024 08:26 PM
how do I go about getting an engineer
Message posted on 15 Jun 2024 08:28 PM
Contacting Sky directly @andy+peace
Message posted on 15 Jun 2024 08:40 PM
Many thanks
