Discussion topic: Sky channels pin protected
Message posted on 20 Apr 2025 06:54 PM
Hi does anyone know why some of the sky channels are suddenly pin protected. Its currently 6.45pm and i cant access
sky showcase
sky witness
sky atlantic
sky msx
sky max
sky max
there may be more.
never been a problem before.
its very annoying no kids in the house do i i have no need to resctrict viewing.
i have tried the settings- parental menu with no luck.. anyone no how to fix this.
Message posted on 20 Apr 2025 07:00 PM - last edited: 20 Apr 2025 07:00 PM
Re: Sky channels pin protected
If you're watching age restricted content pre watershed then it'll always ask for the pin regardless of your settings. It is an Ofcom requirement that Sky must adhere to and cannot be overriden by Sky or you.
Message posted on 20 Apr 2025 09:09 PM - last edited: 20 Apr 2025 09:10 PM
Sky Atlantic was showing White Lotus, and that's always going to need a PIN up to 21:00
It's the application of Mandatory Daytime Protection which permits transmission before the watershed.
