2
This discussion topic has been answered Discussion topic: Sky cable
This message was authored by: Cindy63
Sky cable
Hi
I tripped over my sky Q cable and can't get it back in again, my tv is on the wall but it's the end that has tiny wee wires and every time I try to put it in the wires all bend ... can I get another cable that not ske to fit, these wee wires are so fiddly and I can't see properly because it's on the wall.
also can someone please confirm what port it should be going into? Any help appreciated .... thanks
This message was authored by: Invisiblename Answer
Re: Sky cable
@Cindy63 wrote:
Hi
Do you mean the HDMI cable? If so, you need to replace the cable, you can't just "put the wires back in". HDMI cables are readily available on the famous online store, just measure how long your current one is, as they come in all sorts of lengths.
I am just another Sky customer!
Re: Sky cable
@Cindy63 wrote:
Hi
Avatar for Cindy63
Re: Sky cable
Hi
thanks very much for that, I had someone visiting that days and that  is exactly what was wrong, the connector was still stuck in the socket and I didn't realise either, got new cable so all sorted.
Appreciate your help
thanks
Cindy
