Discussion topic: Sky box
Message posted on 16 Dec 2025 10:09 PM
Sky box
Not taping downloading
Message posted on 17 Dec 2025 04:35 AM
Re: Sky box
Can you provide more information if you want some advice?
Are you experiencing problems when recording and downloading?
What's happening when you try?
Have you tried rebooting your Sky Q box which fixes a multitude of issues, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
