Discussion topic: Sky box
This message was authored by: Odetteward
Sky box
Sky box won't connect to the internet & keeps coming up ERROR: MR001
Re: Sky box
This has nothing to do with Sky Go, the forum you posted in
Which Sky System do you have?
• Sky Plus (Sky Plus Forum)
• Sky Q (Sky Q Forum)
• Sky Stream (Sky Stream Forum)
• Sky Glass (Sky Glass & Live Forum)
Re: Sky box
Hi @Odetteward I presume you are talking about the SKYQ Mini box?
Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on, then do the same with the Mini box?
Avatar for Odetteward
Re: Sky box
Thank you @Quoman7 for your reply, I am now sorted as I rang sky in the end.
