Discussion topic: Sky box
Message posted on 09 Jun 2025 10:00 AM
Sky box
I have to keep turning my main sky box off at the main power point wait and turn it back on to get it working same with the muti room boxes
Message posted on 09 Jun 2025 10:12 AM
Re: Sky box
Hi @Aiden13
(Resetting the settings will also reset:
Settings changed within the hidden engineer menu, include LNB type. If on a communal dish you need to reset the LNB to SCR in the hidden menu. After changing the LNB type you need to reboot the Q box.)
Message posted on 09 Jun 2025 03:02 PM
Re: Sky box
Message posted on 09 Jun 2025 03:05 PM - last edited: 09 Jun 2025 03:07 PM
Re: Sky box
Try following this link. It should lead to a replacement box if needed
https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box.
