4
This discussion topic has been answered Discussion topic: Sky box
This message was authored by: Justine+Fiona
Sky box
Sky box not connecting to tv
This message was authored by: PandJ2020 Answer
Re: Sky box
@Justine+Fiona wrote:
Says. No satalite signal but all other things conected
No satellite signal would indicate an issue with your dish...  You'll probably need an engineer to check it.
Re: Sky box
Hi @Justine+Fiona Try putting your TV and SKYQ box on standby, then turn your SKYQ box on with the power button on your SKYQ remote, your TV should turn on with the SKYQ box connected?
Avatar for Justine+Fiona
Re: Sky box
Re: Sky box
Re: Sky box
Thanks. Been on hold for 35 mins for help. Nightmare thanks for input
Answered - Go to Answer
