Discussion topic: Sky box won’t turn on
This message was authored by: Dean12
Hi, my sky box won't turn on
Re: Sky box won’t turn on
Hi @Dean12
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing all the above
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
This message was authored by: APJudge
I managed to get mine to work. I done the factory reset and got to the connection screen where it would always fail to connect. I decided to connect via mobile phone hotspot which worked everytime. First time it downloaded the update and then back to not coming on but second time it updated and went through the setup and now works. It's also automatically connected back to my house WiFi.
This message was authored by: Enots
Try changing your settings preferences from Eco to Active.
This message was authored by: Invisiblename
You're responding to a post from September 2024!
I am just another Sky customer!
This message was authored by: Rosiebear
My new sky q remote  won't connect to the sky box
@Rosiebear Have you tried rebooting your main Q box ie
then
Try resetting your remote.
Press the buttons 7 & 9 together on the remote until it’s led flashes four times.
Then press 1 & 3 together until the led flashes twice then follow onscreen instructions to repair the remote.
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
