This discussion topic has been answered Discussion topic: Sky box won’t supply signal to TV
Message posted on 18 Dec 2024 06:02 PM
Sky works fine following a reboot of the Sky box but overnight loses connection and requires a reboot again next day. System has been doing this for 6 months and getting progressively worse.
Message posted on 20 Dec 2024 09:59 PM
If you end up doing a 'doorstep box swap' whereby DPD deliver a new box and take your faulty box away, remember to remove the viewing card from the old box before it disappears into the van.
Message posted on 18 Dec 2024 07:33 PM
Re: Sky box won’t supply signal to TV
Message posted on 18 Dec 2024 10:12 PM
TV indicates that there is no signal from the HDMI input, I power down the sky q box for 10 seconds and then power back up, sky box goes through reboot process and then signal is restored and it works fine. Following day process is repeated.
Message posted on 18 Dec 2024 10:22 PM
Hi @Elf490
Message posted on 19 Dec 2024 08:33 AM
Hi @oldfella ,
Thanks for the information I will try this today and let you know how I get on!
Kind regards
ANdrew
Message posted on 20 Dec 2024 09:36 PM
Hi @oldfella ,
Sorry it took so long to reply, the fix/reboot process is not quick. I have ordered a new sky box as I am unable to get my current one to work as expected.
Thank you for your input and patience!
cheers
Andrew
Message posted on 25 Dec 2024 04:46 PM
Hi there, saga continues! Sky q box now connected to internet with all relevant IP addresses correct etc. however error message displays 'it looks like you don't have internet connection right now' even though the new sky box I received required an internet connection to pair the viewing card. Any ideas please?
