Discussion topic: Sky box stuck on red light
This message was authored by: Oreilly465
Every night when I come home from work my sky q box is stuck on red. I have taken the plug out and put it back in and that normally works. If it doesn't I do a reset. Tonight neither is working. I am out if options. Can anyone help
Re: Sky box stuck on red light
Hi @Oreilly465
This is nothing to do with the boxes being in ECO mode is it?
https://www.sky.com/help/articles/using-the-standby-settings#:~:text=Changing%20the%20standby%20sett...
Avatar for Oreilly465
I don't know, I haven't set it to eco mode that I know of. But I can't get it on to find out
Hi @Oreilly465
Have you tried Turning the Q box on by pressing the Standby button on the front right of the the box (the Amber led).
If this turns the box on Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
My light is red, pressing it doesn't do anything. I have repaired the remote, but still nothing
Hi @Oreilly465
You can only pair the remote when the Q box is on with green led.
is your Red light in the centre of the Q box or on the right hand side?
This message was authored by: Nezie13
The red light is on all the time
When I try and use the remote control it doesn't work,it won't turn it off at all
Hi @Nezie13
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
