Discussion topic: No internet connection
This message was authored by: lemondrops
So frustrating!  Sky q mini box has been dropping out for a while now but it does eventually come back on.  Main box saying no internet now either.  Have reset it so many times this day only for it to drop out again in minutes.  Been holding on to speak to Sky and the call just got cut off 😡. Internet (not Sky) working fine.......
Any ideas?
Re: No internet connection
Any ideas?
Hi @lemondrops
Reboot the mini as above.
